55 pan gasket and rear main seal - NCRS Discussion Boards
  • Fenwick B.
    • January 1, 2005
    • 115
    I'm replacing the rope packing on my 55, and would like to know what sealant I could use on the pan gaskets, and if I should use it on the rear man seal?
    Fenwick Binder
    Re: 55 pan gasket and rear main seal
    If you're using an original-type rope seal, no sealer is used on the mating ends of the seal after t*******; however, the rearmost 1/2" or so of the mating surface between the main cap and the block requires sealer.
    A much more reliable updated 2-piece polymer seal to replace the old rope seal is available from Paragon (#4340K), Fel-Pro (#13241, I think), or #BPE-200 from Gary Pronesti, (352) 253-1957, or #010309 from Danchuk.
    I've had good luck with Permatex "Ultra-Copper" hi-temp RTV.
    Edit: I guess the censoring robot doesn't like the word T R I M M I N G
    • Fenwick B.
      • January 1, 2005
      • 115
      Thanks for the response. I'm using the new 2 piece type seal. Should I put any sealant where they meet?
      • Michael L.
        • July 31, 2005
        • 562
        I used Permatex copper when I took the rope seal out of my '55 265. I did put a spot of the sealer between the seals where they joined.
        Mike
        • Fenwick B.
          • January 1, 2005
          • 115
          The new seal worked. No Leaks! Thanks for the help.
