Looking now for help with a coil.
See excerpts from an on line discussion and whether the correct NCRS judge-proof coil does or does not have two RAISED bosses and does or does not have the "091" and "12 V" embossed 1 1/2" from the BOTTOM of the canister.
Thanks much for clarity.
Bill
Quote:
Originally Posted by Dave Strickland
Are you sure that you want the 091 to be 1 1/2" from the bottom. There is an older NCRS Restorer article that may contradict that. Prior to 1962 the coils had no raised bosses at the tower but around that time frame the bosses were introduced. I'd be interested what others think.
Dave, I went through my Corvette Restorer CD and found an article that you may be referencing. "Identifying 1953-1974 Factory Installed Delco-Remy Ignition Coils" by Kenneth Kayser.
One particular papagraph caught my eye. "One other change should also be noted. The 1115091 Ignition Coil was last used as OEM on 1964 high-performance Corvette engines. On March 8, 1967 the embossed "091" and the "12 V" underneith it was lowered 2 1/2" on the container (the figure 7 shows where the info was before and after the change). Why this was done remains a mystery, and futher research needs to be done to determine if other ignition coils were likewise affected"
This clearly suggests that prior to the change in 1967 the info was near the TOP rather than near the bottom of the container. Yet some suppliers offer this so identifyied coil but with footnote that it might not pass NCRS judging?????????
The plot thickens!
Bill
The plot thickens!
