Well, I've gone and done it! I am having the body lifted and the frame refurbished (as opposed to restored) to get my beloved coupe on the road to recovery. My first decision and inclination is to have the frame electrolitically (sp?) stripped as opposed to media stripped. My logic is to clean it inside as well as outside and powdercoat instead of paint. This car is a CE block, but otherwise pretty original as far as I have been able to determine. I have searched the archives and as far as I could see, there were a lot of differeing opinions (except for maintaining originality). Has anyone had any good or bad experiences with powdercoating the frame, especially inside, other than possibly having to chase all the threads?
I HAD the build sheet at one time, found inside the left front frame rail, I think, right behind the upper control arm. I thought I saved it somewhere,but I can't find it now. I will look again as soon as the frame is lifted although I don't believe I put it back. I should stick my PINHEAD inside the frame to look again! If I only knew then what I am learning now!
