60 oil pan - NCRS Discussion Boards
60 oil pan
  • Dick G.
    • May 31, 1988
    • 681
    60 oil pan
    What are the characteristics of a 60 corvette oil pan? How about timing chain covers? Thanks DG
  • William C.
    • May 31, 1975
    • 6037
    Re: 60 oil pan
    Although my '60 Knowledge base is limited, the first question would be "What HP engine are we considering here?"
    Bill Clupper #618
    • Dick G.
      • May 31, 1988
      • 681
      Re: 60 oil pan
      Bill: I am considering the 290HP version engine. I don't have my JG on this year in my hands yet. On order. Thanks DG
      • William C.
        • May 31, 1975
        • 6037
        Re: 60 oil pan
        Well, I'm sure someone will help, but the part number I'm showing in the '60 parts book is 3769761, which later was replaced by the 3789629, used thru '62. It's a five quart pan as best I can see, and if the same as '61-2 should be a three step pan, with the drain on the bottom of the lowest sump. If others determine the pan is the same as A '62, I can take a picture of my '62 FI pan and email it to you if you need.
        Bill Clupper #618
        • Loren S.
          • November 1, 2002
          • 172
          Re: 60 oil pan
          • Loren S.
            • November 1, 2002
            • 172
            Re: 60 oil pan
            • Loren S.
              • November 1, 2002
              • 172
              Re: 60 oil pan
              • Loren S.
                • November 1, 2002
                • 172
                Re: 60 oil pan
                • Loren S.
                  • November 1, 2002
                  • 172
                  Re: 60 oil pan
                  • Robert D.
                    • April 1, 2003
                    • 305
                    Re: 60 oil pan
                    how would the #359937 pan do for judging in a 59? would it get nocked for originality?
                    sounds like it would be big point deductions?
                    • Lou C.
                      • August 31, 1992
                      • 134
                      Re: 60 oil pan
                      I think most judges take 2 points for the 359937 pan. It is pretty close.
