Help with a 63 Tach - NCRS Discussion Boards
Help with a 63 Tach
  • Paul H.
    • January 1, 2005
    • 2
    Help with a 63 Tach
    The plastic end of tach cable on my 63 broke inside the tach. I tried a number of times to pull the broken part out while the cluster was in. No luck.
    So today, I started taking things apart and one thing lead to another. Now I have the tach out of the cluster, in my kitchen. I can see the broken end, but I can't get it out. I've tried a scribe, even heated it, but no luck.
    Its a beautiful weekend & I'd like to be driving the car. I hate the thoughts of shipping it off to an insturment repair shop for a few weeks to get it repaired, while my car sits....
    Any suggestions?
    Paul
  • Paul Y.
    • September 30, 1982
    • 570
    Re: Help with a 63 Tach
    I'd try super glue on a pin head. Good luck Paul
    It's a good life!
    • Paul H.
      • January 1, 2005
      • 2
      Thanks for the suggestion Paul. I thought about glue, but the hole is so small, i thought i would glue it shut!!!
      i took a 1/16 drill and drilled down about 3/8". Then i took a small sheet metal screw and twisted it in. Pulled right out!!
      now all i have to do is put it back together.
      Thanks again.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12695
        Drive the car without Tach, it is not mandatory to have one!!!
        Rob.
        NCRS Software Developer
