Just installed a new clutch assembly (3 finger) and even though adjusting the fine threaded rod, we can't seem to adjust the clutch linkage so the gears with shift without the noise happening, which we think is caused by the clutch fingers touching the clutch plate, when the pedal is fully depressed. Almost impossible to shift at a standstill, but a bit easier when moving. Has anyone experience similar issue and solved, or is there a specific way to adjust the linkage. Thanks Susan.
C1 '58 clutch adjustment
Re: C1 '58 clutch adjustment
Susan, had a similar problem years ago on my 58. Somehow I put a 'short' style throwout bearing in it but it required a 'long' style bearing to fully disengage the clutch pressure plate. Might be your problem?
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Just installed a new clutch assembly (3 finger) sounds like it has a weak spring or using wrong TO bearing. and even though adjusting the fine threaded rod, we can't seem to adjust the clutch linkage so the gears with shift without the noise happening, which we think is caused by the clutch fingers touching the clutch plate, if so your over center when you push the clutch in.when the pedal is fully depressed. Almost impossible to shift at a standstill, but a bit easier when moving. Has anyone experience similar issue and solved, or is there a specific way to adjust the linkage. Thanks Susan.- Top
Dan, thanks for the quick reply. Have installed brand new spring, new TO bearing (the thicker "passenger car" bearing) The thinner bearing would not allow us to shift at all.
Have to go easy on me,,, not a mechanic, so not understanding what you mean by "over center" ... Very frustrated "clutched out" owner.
Thanks Susan- Top
Thanks Susan
It means as you push the clutch in the travel is to fare causing the clutch to grab. Check and see if the TO touches the three clutch fingers at the same time , if one is not that's your problem.- Top
Attached Files- Top
You dont the springs are no good weather it's new or not, that's why the clutch hangs up between the plate and flywheel and it's hard to get in gear.Can you check it out to see if the TO is hitting the three fingers at the same time??- Top
