'67 Engine Temp Readings - What Ya Think - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
  • Rick S.
    • January 1, 2003
    • 1203
    Re: '67 Engine Temp Readings - What Ya Think
    Looks like your radiator is working great!
    • Kirk M.
      • June 30, 2006
      • 1036
      Kinda what I thought too. Also good to know the temp gauge is reading dead on! I was surprised at how hot some of the heater hoses were as well as the exhaust manifold.
        • 15610
        Your exhaust manifold temperatures are good. They indicate whether the engine has the correct total idle timing, and they should be no more than about 500 F on a non emission controlled car.
        A ported vacuum advance system used on emission controlled engines will raise the exhaust manifold temperature several hundred degrees.
