Does anyone ever use a tumbling barrel to clear bolts/nuts/screws/small parts??? Any hints and tips on usage of such a device???
I've just bought a 4lbs set with little steel balls, little sticks and little satellite shaped tumbling material. I've also added some polish abrasive to the water which needs to be in the barrel as well. I'm currently tumbling some rusty and painted bolts and a washer to check for the result...
greetings,
Rob.
greetings,
Rob.
