68 rear spring - NCRS Discussion Boards
68 rear spring
  • Joseph C.
    • April 1, 2006
    • 48
    68 rear spring
    After installing the rear leaf in a body off, how much arc, or how high is the car?? it looks alittle high.
    Re: 68 rear spring
    The free arch spec for std 9-leaf springs is 10-inches. You measure this with the spring un-installed by drawing an imaginary line through the center of the end mounting cup holes and going up from that line to the bottom center of the spring.
    Once the spring is installed, do NOT expect it assume it's final rest position until the car has done some 'bouncing' on the road (25 miles ususally gets it)....
