timing light hook up C3 - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    I have a timing light that the positive and negative are short, how will I hook them on a C3 with the battery in the rear? thanks
    Re: timing light hook up C3
    Lyndon-
    Connect the red clip (hot) to the output stud on the alternator, and the black clip (ground) to any bracket on the engine.
      • 11608
      I use the horn relay. Works well, and it's right where you will stand to use the light anyway.
      Patrick
      • Clem Z.
        • January 1, 2006
        • 9427
        buy one of the newer timing lights that use 2 "D" flashlight cells to power it and requires no hook up to 12 volts DC power. they work well even for power timing at high RPMs and they cost about $50
        • Paul M.
          Infrequent User
          • June 30, 2004
          • 21
          And for one final option, Use another battery. I used a 12V gel cell from my sons ride on plastic jeep. Just set it on the floor by my feet.
