ignition key - NCRS Discussion Boards
ignition key
  • Chris S.
    • March 28, 2007
    • 139
    ignition key
    I'm trying to replace the ingnition key and female end, I think you take a small rod and stick it in the hole, but then do what? I'm lost. I turn it and nothing happens. Am i missing a step?
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1464
    Re: ignition key
    If you are referring to the ignition lockset, I did this just yesterday to confirm the key code stamped on the side of the lockset.
    Insert the ignition key, turn left to Accessory, press a paper clip, or equivalent into the hole to release the catch, jiggle and pull, the assembly should come right out.
    HaND
    • Chris S.
      • March 28, 2007
      • 139
      Re: ignition key
      thanks for replying, how far does the paper clip go in roughly?
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1464
        Re: ignition key
        WOW, I never really measured, but, not far, maybe 1/8" - 3/16's of an inch.
        If farther, you may be missing the small tab that you want to depress.
        HaND
          Re: ignition key
          Turn to accessory, insert paper clip to depress spring-loaded plunger, then continue turning counter-clockwise and the cylinder will pop right out.
