C2 Knock Offs - NCRS Discussion Boards
C2 Knock Offs
  • Robert T.
    • May 31, 1993
    • 346
    C2 Knock Offs
    Could some one please post or email me some pictures of their original knockoff wheels. In particular, some close up views of the area where the cone meets up to the wheel. I have some new repro direct bolt ons and I am getting some conflicting opinions as to what is correct relative to that fit.
    The question is whether the cone should meet/touch the wheel or not. Some say yes, some say no. I can't decide if the cap that I have is correct or not. The supplier says there should be a gap, others say no gap. I've never really paid any attention to that area before.
    Can someone please help me out here as to what is correct? I've attached a couple of pictures of mine.
    Thanks.
    Bob Taylor (22650)
  • Charles R.
    • April 30, 2006
    • 13
    Re: C2 Knock Offs
    What year?
    Here is known original 64 with original BF Goodrich tire, photo angle may not show what you want but yours do not look correct. This is before restoration.
    • Mike M.
      • May 31, 1974
      • 8365
      Re: C2 Knock Offs
      Thanks.
      Bob Taylor (22650)
      i have 10 sets of orignal K/O's on my midyears and some cones touch and some just barely avoid touching. i believe the lack or near lack of gap is dependent on the amount of adhesive that was applied by kelsey hays. your gap appears excessive in your photo. regards, mike
      • Gary S.
        Super Moderator
        • February 1, 1984
        • 456
        Re: C2 Knock Offs
        It appears real cones end closer to the fins than the typical repro. They are not suppose to touch the fins in any case. Below is a picture of a repro cone (left hand picture) that you typically get and on the right is a real 65 KO wheel cone. The real cone gap here is exactly like McCagh's picture of his real 64..it ends closer to the fin.
        Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
        • Robert T.
          • May 31, 1993
          • 346
          Re: C2 Knock Offs
          Thanks for the info guys. Sorry I forgot to say that this was off a 66.
          • Robert T.
            • May 31, 1993
            • 346
            Re: C2 Knock Offs
            Thanks Mike
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1464
              Re: C2 Knock Offs
              Hi Gary
              Interesting color sequence on that cap.
              HaND
              • Gary S.
                Super Moderator
                • February 1, 1984
                • 456
                Re: C2 Knock Offs
                Mike, Just had to make a correction to my post...I got the pictures mixed up and that was because I had to upload them a couple times...the real KO is on the right, not the left as I first posted. Gary
                • Robert T.
                  • May 31, 1993
                  • 346
                  Re: C2 Knock Offs
                  Hmmmm. At least in both cases the end of the cone is away from the fins. That's good. However, neither one has a gap like mine. It sounds like from Mikes post that some originals may not have touched the wheel. That's encouraging, but mine still looks "wierd"
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Re: C2 Knock Offs
                    Originally posted by Mike Murray (25129)
                    Hi Gary
                    HaND
                    Mike -- you must be referencing the more "traditional" red-white-blue, in a clockwise observation. The original blue has weathered the most.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Re: C2 Knock Offs
                      Robert -- here's a poor attempt to take a pic (with mirror to show slightly different angle) of the cone on one of a set of '66 originals I have. The skirt of the cone contacts the wheel casting right up to the edge, except for maybe an half-inch, where I'm not sure even a 2-thou feeler would slip under.
                      But this is a sample of one wheel; I have not had the advantage of owning more than 3 original sets in my Corvette lifetime, and Mike McC.'s observation may well be the one to use.
                      • Robert T.
                        • May 31, 1993
                        • 346
                        Re: C2 Knock Offs
                        Are these caps different from left side to right side. Is it supposed to be R-W-B in the direction of travel?
                        Bob
                        • Robert T.
                          • May 31, 1993
                          • 346
                          Re: C2 Knock Offs
                          Wayne,
                          Thanks for taking the time and effort to do this.
                            Re: C2 Knock Offs
                            The cones were affixed to the wheels using various methods to thwart the potential for 'rattling'. Some originals I've seen used what appeared to be putty while others used a form of double sided tape.
                            In either case the absolute thickness of the anti-rattle agent dictates how high off the wheel the cone sits. My hunch is the reproduction wheels/cones you have are joined by pretty thick pieces of double sided foam tape...
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              Re: C2 Knock Offs
                              Are these caps different from left side to right side. Is it supposed to be R-W-B in the direction of travel?Bob
                              Bob -- This may be a legend about left side caps being different from RH, so that R-W-B was the order going forward on both sides.
                              I can only see a single GM part # for service of these emblems. But then the AIM RPO P92 calls the spinner "nut assembly", which would lead one to assume center cap / emblem was included --- and if the spinners were different L to R, then why not the caps ?
                              I dunno; maybe Mike Murray might have something to add.
