C3 Axle Year and Ratio - NCRS Discussion Boards
  • Joseph M.
    • May 7, 2007
    • 65
    A friend of mine gave me a cast Iron C3 axle and I would like to confirm with you what the year and ratio it is. On the bottom I found the identification number AWW 171 E1. I believe it is a 1971 with a 3.08:1 gear ratio
    Thanks!
    Re: C3 Axle Year and Ratio
    The stamped code translates:
    AW 3.08 ratio
    W Warren Motive axle Plant
    171 Manufactured the 171th day
    E Eaton posi unit
    1 Built on 1st shift
      The casting number and casting date are on the driver's side, adjacent to where the strut rod bracket bolts on - that will give you the year.
