I found only a single article in the archives referencing blasting material for the frame. That writer recommended 000 sand on the frame. Now that I think about it, possibly someone else mentioned "beads." I am ready to blast the frame and parts. Specifically, what "beads" are recommended? Does anyone have any experience with "brown aluminum oxide?" Shoud the same material be used on the frame and the parts? Are there some parts that should be cleaned using a different method? Are there other questions that I should be asking? I have been a member less than 2 weeks and have found everyone's suggestions to be tremendously helpful. Thanks to you I am "patiently" trying to get the undercoating off the stencil!!
