New front springs - NCRS Discussion Boards
New front springs
  • Gary N.
    • August 31, 1986
    • 118
    New front springs
    I need to replace the control arm bushings on my 66' AC coupe. The front springs have never been replaced and sits a little lower on the drivers side, so I thought I would replace the springs while I have it apart. Where is a good place to get new springs and did the AC and non AC vettes have the same springs.
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
  • Craig O.
    • July 31, 1983
    • 207
    Re: New front springs
    if you have a small block part#3851100 for both ac and non ac.
    originals are progressive coil springs. they are not available from GM any longer. I have been looking for a set for some time, either nos or good used. so good luck.
    • Dick G.
      • May 31, 1988
      • 681
      I recently installed new front coil springs into my 65 sb, no a/c. I bought the springs from Paragon Reproductions. They worked out great. My car was sitting over 2 inches high. John H. speaks highly of going to the source (Eaton). DG
      • Gary N.
        • August 31, 1986
        • 118
        Craig,
        Volunteer Vettes says that they have the "correct" reproduction springs for the midyears @ $48 ea. Are you just trying to find the GM ones?
        Gary Nyland
        1955 Nomad
