1970 - Ebrake Catch 22 - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    Re: 1970 - Ebrake Catch 22
    OK - finally freed the rotor - no magic, just lots of Kroil in the area where the ebrake drum is - lots of tugging on the cable...which gave up maybe an eighth of an inch - but between the two, that did the trick - having said that, i have put the cable assembly off for another day, because other than that 1/8", it is still seized and i cannot get the cable off - but the car does roll and can now come off the lift spot it has monopolized for 6 months of immobility!! - thanks to all, sl
    • Chuck S.
      • April 1, 1992
      • 4668
      If it moved 1/8", the battle is won...it just won't seem that way for a while. It's no longer rusted together, but rust scale is wedging between the casing and the cable preventing movement. Keep moving it...back and forth, back and forth, back...well, you get the idea. With each direction change, the movement should increase...just keep working it.
      • Joe W.
        • March 1, 2000
        • 88
        #18
        Hello,
        I'm not sure if this can help, but last fall when I was working on
        replacing my brakes, once I got the rotors off it allowed access to the
        emergency brake cable and the emergency brake pad/ assembly.
        I know my emergency brakes were ceased up and the cable as hard
        as a rock. Like you, I soaked the inner cable with a penetrating spray,
        only I used PB Blaster.
        I knew it was still going to be a while before the car was going to
        be on the road (time to dry) so I sprayed the heck out of the ER springs,
        shoes - no choice really if I wanted to have a chance of breaking it free and
        after (2) through soaks, sprayed down both sides every 2 hours, by morning
        I was able to grab the shoes and after a few nudges back and forth,
        they broke free.
        I would highly recommend PM Blaster. It smells awful, but it works divine.
        The bad smell tells me it means business!
        • Stephen L.
          • August 29, 2007
          • 205
          #19
          joe - many thanks - the pictures in particular are very helpful - sl
