Was wondering what the bolt thread size and length is when securing the WW Wiper Door Actuator (1969/E1969) to the Actuator bracket coming off the firewall ? Thanks
1968/69E WW Door Actuator Bracket Bolt Size ?
Re: 1968/69E WW Door Actuator Bracket Bolt Size ?
These are special shoulder bolts for the 68-early 69 application. There is no substitute.
Corvette Cetral has them. Part # 653125 at 4.75EACH
- Top
Greg-----
The bolts used for this application were a special shouldered bolt, GM #3945359, with 10-24 thread size. They're long-since GM discontinued. Fortunately, they are available in reproduction. They are used in conjunction with white, plastic bushings, GM #3922010, which remain available from GM.In Appreciation of John Hinckley- Top
