I'm putting my '61 back together and can't seem to find a good picture of where the headlight wiring harness extensions penetrate the inner fender or the size of the hole and whether there is a rubber grommet. I have new reproduction inner fenders and see a shadow of a circle about 3/4" in diameter down around the indentations for the bumper brackets. I'm wondering if maybe thats from a mold that was made from an original. Any ideas. Thanks in advance.
C-1 Wiring
Tags: None
- Top
Re: C-1 Wiring
Stu,
Thanks for your reply and cycling my post back to the top. Maybe someone with that information will be on the board tonight.
Cheers,
Richard Perkins- Top
Re: C-1 Wiring
Hi!
I have two 61s and one with the body currently off the frame. I can get you pictures and dimensions on Saturday. Please email me at: ray63@rochester.rr.com if you still need information.
RayRay Carney
1961 Sateen Silver 270-HP
1961 Fawn Beige 315-HP- Top
Re: C-1 Wiring
Richard,
If the hole in the inner fender looks about like this in the pic, you ought to be fine. And, yes, there is a rubber grommet to help keep out splashing from the wheel well. It is the same one as on much of the firewall.
BobAttached Files- Top
