Holes in C1 rear frame crossmember - NCRS Discussion Boards
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: Holes in C1 rear frame crossmember
    Bruce, thanks. Trying to determine approx VIN when the changeover was made from your type of rear frame crossmember to the later one like mine. So far my VIN 300X appears to be the earlies we've come across. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Bryan H.
      • August 31, 2004
      • 120
      Gentlemen is it possible some early C1's didnt have any holes in them? I have a very early 56 (76) and i looked at the rear cross frame and it is completely solid. Everytime i get one thing handled it seems another question pops up. Any input will be greatly appreciated. Bryan
      • Peter R.
        • June 19, 2011
        • 233
        On page 89 of the NCRS Technical Information Manual & Judging Guide for '56-57, it says the changeover from 5 holes to 7 holes was approximately '57 VIN 2800.
        P.S. My '57 VIN ...646 has 5 holes.
        Pete
        1954 Corvette #814
        1957 Corvette #646 -- FI, 3-speed
        • Brian W.
          • September 30, 1990
          • 216
          My 57 SN. 25X has 5 holes- 2 go through. Brian
          • Gary C.
            Administrator
            • October 1, 1982
            • 17549
            Bryan,
            IIRC the holes are carry overs from '55. No holes would be out of the norm.
            Looking forward to seeing your very very early '56.
            Gary
            NCRS Texas Chapter
            • Joe M.
              • February 1, 2005
              • 589
              One is off a 57, the other off a 61
              • Bryan H.
                • August 31, 2004
                • 120
                yes Thank you Gentlemen. the more I look and read the less i know. The rear crossmember must be an aftermarket job, it is bolted not rivieted, i will probably start looking for a correct early 56 rear crossmember, I was lucky enough to see an ealry corevtte today up close and personal.
                • Adam S.
                  • July 30, 2008
                  • 167
                  My 57 has 5 holes in rear crossmember, VIN is very close to 2400 .
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17549
                    #24
                    Bryan,
                    Vette Products of Michigan are the only ones that reproduce frame parts from the original GM stamps.
                    Their rear cross member is the late 57-62 version. The holes will have to be welded and redrilled. Don't know if the have the rivets or not.
                    Gary
                    NCRS Texas Chapter
                    • Bryan H.
                      • August 31, 2004
                      • 120
                      #25
                      Gary..Thanks that is good news. this solves another problem, I am collecting everything before i start taking it apart.
