Brass Tube Source/Size for Vaccuum Override Controls - NCRS Discussion Boards
  • Greg R.
    • April 1, 2005
    • 47
    Hello;
    I need the size and hopefully a source for the 4 small brass tube inserts that connect the 4 striped vaccuum hoses (blue x 2, red and white) to the (2) rubber 90 degree angled boots that connect directly to the (2) pull valve type plastic override controls under the dash. Please help if you can...I ahve a early production '69.
    Thanks in advance.
    Greg
    • 43193
    Re: Brass Tube Source/Size for Vaccuum Override Controls
    Originally posted by Greg Roccaro (43631)
    Hello;
    Thanks in advance.
    Greg
    Greg-----
    This is the type of part that if Dr. Rebuild doesn't have it, you might just as well forget about finding it. And, as far as I know, he doesn't have it. So, I'd say your choices are about as follows:
    1) find a used vacuum harness with the ends on it and salvage the pieces you need;
    2) fabricate the inserts from brass tubing stock you can purchase in a hobby shop or some hardware stores.
