LICS is selling a metal cup and flat grommet for the early 63 crankcase breather hole behind the intake manifold. TIM&JG just mentions a grommet, no distinction between 63 and 64; I suspect what I know as the big rubber grommet. Is this LICS part for real? If so was the metal cup installed before engine paint? Thanks. Gerry
63 Breather Grommet
Re: 63 Breather Grommet
What does the assembly sequence look like for this? That may tell us whether it is painted or not. Anyone have a picture/drawing. I know I'm not familiar with there being a "cup", but then I've never had my 63 engine apart that far.
Stu Fox- Top
Looking further. The AIM Sect 6 Sheet B1.00 is dated 10 May 63 ..... same date cited by LICS as the conversion.
AIM shows removal of a 3715628 grommet and 3727693 retainer; replaced with a 3831671 (the big typical) grommet. Since covered in the assembly manual then I would believe this retainer was line installed and thus not painted on the engine at Flint.
With all the 63s on this forum I would hope some member could confirm from his early original car.
Gerry- Top
My 63, built May 14th, 1963 had the metal cup and small rubber bushing. I havent gotten around to buy the Long Island part to see if it is good, but I would assume it is. Anything earlier than my car would also need the metal cup / small bushing.
I cant comment on if its supposed to be painted or not, my engine had been touched up before I got to it.
Long Islands drawing of the part looks correct.
Boyan- Top
A correct NOS part is extremelly rare.
The OD of the original sleeve is about .260
The OD of the repro is .250
So if you are going to use it be careful as you might have to expoxy it in.- Top
John,
I did buy the grommet with the metal cup for my Jan 63 car. The .010 difference makes it slide in way to deep into the hole where its supposed to stay flush with the block. I'm going to put it in with epoxy or kwik weld just to hold it in place permanently and stay flush with the block.
Jerry- Top
Jerry my car had the cap with the smaller grommet when the machine shop did my block they removed it and tossed it in the trash, I just used the bigger grommet. I don’t know if I would use epoxy to hold the cap in place, a lot of heating and cooling cylce’s. My car has been through (3) Flite judging events no one said a thing.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
The sleeve and bakelite grommet on the '63's was in most all of the Flint engines in old days. I don't know if it was in the Tonawanda blocks or not.
A NOS one has/had a grommet that was hard as rock. I assume it was rubber was new. My engine builder had a tool to remove the sleeve without ruining it so it could be used again.- Top
It’s my fault that Richard had an issue with the sleeve and grommet assembly. Been holding this tidbit back from you. I had a NOS assembly but didn’t give it to him to copy.
He did a decent job on his part. Just a tad loose which is quite easy to handle. John- Top
