1960 Hood - NCRS Discussion Boards
1960 Hood
  • Dick G.
    • May 31, 1988
    • 681
    1960 Hood
    I need a hood for my 1960 corvette. Will a 59, 61, or 62 also work? I will be looking for one at Bloomington in 2 weeks. Anyone? Thanks DG
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 1960 Hood
    Dick...
    The underneath side of 59, 60, 61 & 62 hoods are different. ( see Roy Braatz picture posted in Dec. 2007) If keeping the car original is not a concern... they will fit, unless you have a top tank radiator.
      Re: 1960 Hood
      Here's that hood photo - note the difference in the forward rib on the inner panel on the '60-'61 hood and the depression in the center of that rib on the '61-'62 hood.
      • Dick G.
        • May 31, 1988
        • 681
        Re: 1960 Hood
        The hood I have is an old cruddy hood with an amateur hood scoop installed. The hood scoop install did not cut into the backbone/ribs of the hood. My hood looks like the 59-60 hood in the picture, second from the left in the picture. Is the third hood from the left in the picture for top tank radiators only. My 60 serial number is 8234 making her build date about the 1st week in June of 60. Has anyone here bought a repo. hood. Are they any good, with the correct rivets. I will be changing oiut the hood surround this summer on the 60. So I need a hood. At this time, my old hood sits almost 1/2 inch too high in the front after several attempts to lower. Thanks DG
        • Gord H.
          • March 10, 2008
          • 30
          Re: 1960 Hood
          Dick i have a super nice 60 hood for the 60 with top reserve tank applications.
          • Joe P.
            • October 4, 2007
            • 209
            Re: 1960 Hood
            Can anybody shed some light on this?
            "My hood looks like the 59-60 hood in the picture, second from the left in the picture. Is the third hood from the left in the picture for top tank radiators only. My 60 serial number is 8234 making her build date about the 1st week in June of 60."
            THanks.. Also interested in the reply..
            Joe
            • Gord H.
              • March 10, 2008
              • 30
              Re: 1960 Hood
              3 from the left is fo high horse cars will work on low h.p. just not correct.
              • Joe P.
                • October 4, 2007
                • 209
                Re: 1960 Hood
                Thanks for the clarification... I guess then that the second from the left hood will not work with a top tank rad then?
                • Gord H.
                  • March 10, 2008
                  • 30
                  Re: 1960 Hood
                  Joe you got it right
                  • Mark P.
                    • May 13, 2008
                    • 934
                    Re: 1960 Hood
                    My 60 is 8065 and is a May 27, 1960 build date. If my hood is the 3rd from the left is it correct for a 2 X 4 245HP car ?
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Re: 1960 Hood
                      John! nice to see some one uses pic's I post
                      • Joe P.
                        • October 4, 2007
                        • 209
                        Re: 1960 Hood
                        Roy,, thanks great pic!!! A picture is worth a thousand words... but a picture like this is priceless.
                        Joe
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Re: 1960 Hood
                          Joe
                          Thank you for your comment
                            Re: 1960 Hood
                            Roy, I'm just one of many that enjoy (and save) your photos and info!
                            • Mark P.
                              • May 13, 2008
                              • 934
                              Re: 1960 Hood
                              I sent an e-mail with the picture from this thread to Tim Mickey the 58-60 Technical Lead and this is his response which clarifies if the hoods were different for the different engines. He also noticed the 60-61 hood in the picture was a reproduction. Since my hood has the taper at the front then it must be original.
                              Mark,
                              The third hood from the left is the closest reproduction hood for your 1960. It is close, but not correct. The tapered area near the front edge of the hood was tapered on original hoods, not squared off as in the photo. Engine HP had no effect on hood design.
                              Later,
                              Tim Mickey
                              Hello Tim - my hood loook likes the 3rd hood from the left in this picture posted on the NCRS forum. Is it correct for my 245HP 1960 #8065 built 5/27/60 ? Would that answer change if my car was a 230HP or 270HP ? Would it change for an FI car ?
                              Mark #49021
