C3 Jack handle rivit - NCRS Discussion Boards
  • Kenneth T.
    • March 23, 2008
    • 631
    I tried the archives before posting this to no avail. I would appreciate if someone could tell me where or how to get the correct rivit for my jack handle. I have a 1/4" bolt in it now, not real pritty. Thank you.
    Ken
    Re: C3 Jack handle rivit
    Ken
    Ken----
    There are no rivets used on the jack handle. The pivot point between the handle section and the wrench section is a 5/16" OD flathead, steel PIN similar in configuration to a harness pin. However, the pin is set on one end much in the same way that a solid steel rivet is set.
