I had what appeared to be a leaking countershaft in my 66 SB Muncie transmission. I was able to move the trans back from the bell housing about 2 in where I cleaned the area around the countershaft penetration with lacquer thinner. I applied the Right Stuff gasket material in the area and slid the trans forward and tightened it before the gasket material set.
This worked for about 6 months but now I see that the leak has reappeared. I read where others had the same problem but were able to seal it with a small gasket cut to cover the countershaft penetration. John Hinkley also described in his CE article that a gasket can be made to cover the entire front of the trans. This can be installed with the trans in the car by slitting the top of the gasket.
Anyone have experience with the gasket approach?
Dave K.
Dave K.
