What is the correct distributor hold down for '61, 283/230 ? There are two listed in parts catalog- one "flat" and one "wire-style".
'61 Distributer Hold Down
Tags: None
- Top
Re: '61 Distributer Hold Down
Richard, Not an easy question it seems. Now I am not that up on 61's but as far as the FI restos goe I use the pie shaped flat steel ones on 57 to 60. Then I use the wire types on 61 to 65. Don't know if that is correct though but I don't seem to get complaints. John- Top
57 FI distributor hold downs were wire type. Gary....
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
The more expensive and higher quality A-shaped flat holddowns were used early on and sometime into the 1960 model year when they were replaced with the cheapie wire type. So, you should see the wire type from about mid-1960 model year on. - Bob- Top
- Top
