I have a rebuilt 427 - 425HP engine that is in my frame-off 1966 coupe and I have had the Holley carb (original) rebuilt too. I want to set up the carb and was told to use a vacuum gauge for setup. I hooked it on the vacuum line from the vac advance (advance was then disconected) and adjusted the idle to about 850-900 rpm's.
With the engine relatively cold, the vacuum at 900 rpm's was around 10 in. As the engine warmed up (10-15 min.) the vacuum at 900 rpms dropped a bit to about 7.5-8 in. The engine sounded and idled smooth, the vacuum gauge needle was steady, and if I accelerated the engine to about 1500 rpm the vacuum went up smoothly to around 15 in. The needle was not jumping around . I tried to adjust the 2 idle needle valves for maximum vacuum in. but this didnt change the vacuum reading at all. I have not checked the timing yet, but didnt think that would affect the vacuum reading.
1) Is the vacuum reading that I am getting realistic for a newly rebuilt engine?
2) What vacuum in. should I expect if all was perfect?
