Installing the three pads. Right and left are clear. Center piece has me confused. Any diagram that shows its location or suggestion for placement. Thanks.
C1 Firewall Pad Installation
Tags: None
Re: C1 Firewall Pad Installation
Richard,
The center piece placement should be pretty obvious and go right where the piece you took off went - forward of the transmission hump. And there should be the holes for the grommets in it that hold it on that will match with the holes for same in your firewall. There were variations of the insulation for different options so, if you can't match holes, then maybe the one you have is not the right one for your car.
Bob- Top
