The alarm horn on our 1972 sounds when wired directly to a 12-volt source, although not at any other time, such as when the alarm switch is activated and a door opened; I don't see any power going to the alarm flasher; the alarm relay clicks once when connecting the three-wire connector to it, but then makes no further sounds.
From that bit of work, it seems to me like the relay is bad. If that's the case, is there anything that can be done to the relay to make it work? Am I correct that the relay should send constant power to the flasher all the time (when switch 'on' and door open), and the flasher should then 'flash' the sounding of the horn?
Thanks!
Larry
Thanks!
Larry
