C-1 54 starter relay - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    There are three electrical terminals on the starter relay. A purple wire goes from ignition switch to the relay. A yellow wire goes from the relay to the starter, and a black wire goes to the neutral safty switch.
    Question which terminals do those wires attach to.
    I am temporarily by-passing the neutral safety switch, does that black wire need to be attached to a ground for starter to operate?
    Thanks, Ted
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C-1 54 starter relay
    I am temporarily by-passing the neutral safety switch, Yellow and purple you connect when the relay goes bad later on! does that black wire need to be attached to a ground for starter to operate? (NO) the safty switch at the PG is the ground
    Thanks, Ted
    Looking at it _ purple left post- yellow bottom post- black right post
    • Ted K.
      • August 31, 1994
      • 337
      Thanks, Small wiring diagram hard to read.
      Ted
      • Randy G.
        • April 1, 2006
        • 358
        Did a search and found this while trying to confirm the hook up. I came to a different conclusion, because I think connecting the purple wire from the ignition switch to the left post will only energize an unconnected 1/2 of the points in the relay without activating the coil to bring the points together.
        Looking at the relay with the mounting holes up and the center terminal down, isn't the correct way to connect it: black wire (nuetral safety switch which provides ground) is the right side terminal, purple wire is the bottom terminal (ignition switch wire that provides 6 volts to the relay coil and one side of the points...that's why the four terminal relays have a jumper added if you cut off the fourth terminal off to make it correct) and the yellow wire hooks to the left terminal (provides 6 volts to the starter once the coil is energized and the points in the relay make contact).
        Any opinions?
        Thanks.
        • Brett H.
          • January 1, 1996
          • 367
          Any opinions?
          Thanks.
          Randy, you win the prize!! Yellow-left, Purple-bottom, Black-right.
          • Randy G.
            • April 1, 2006
            • 358
            Can I accept the prize in $10's and $20s? Wanna stay below the radar.
            • Brett H.
              • January 1, 1996
              • 367
              From what I understand, as long as you don't earn over $250k annualy, you'll be ok.
              • Randy G.
                • April 1, 2006
                • 358
                True, but I think a tidal wave is coming in about 40 days that may change things.
                • Brett H.
                  • January 1, 1996
                  • 367
                  Swimming trunks ready and waiting for a good swim!!
