1964 Master cylinder and Power booster #'s - NCRS Discussion Boards
  • David P.
    • February 26, 2008
    • 17
    Hello All,
    Can anyone tell me the correct part #'s for the master cylinder and the power booster for my 64. I see some boosters for sale with # 4311 but the judging book says 4310.
    Dave
    Re: 1964 Master cylinder and Power booster #'s
    Originally posted by David Pedersen (48619)
    Hello All,
    Dave
    Dave-----
    The power brake master cylinder for 1964 was GM casting #5464264. I don't know why the discrepancy on the booster numbers.
    • Dan H.
      • July 31, 1977
      • 1365
      Hi, have an original Mar 64 booster, has '4311' stamped at 10:00 and '296' at 4:00. '296' is the Julian date, so that will change, but 4311 is only number I've seen on 64's, not sure where the 4310 may fit in?
      Dan
      1964 Red FI Coupe, DUNTOV '09
      • Michael H.
        • January 29, 2008
        • 7477
        Hello All,
        Dave
        David,
        The 4310 number was never a valid booster number, for any year. It's part of the Delco part number for a power brake/master cylinder assembly, 5464310.
        As others have mentioned, 4311 is the only correct tab number for 64.
        This information has already been forwarded to NCRS/Carlton.
        • David P.
          • February 26, 2008
          • 17
          The Judging manual that I recieved about a month ago lists the 64 power brake booster #'s on pg 123 as 4310 and 4702. I would like clarification.
          Thank You
          Originally posted by Michael Hanson (4067)
          David,
          • Michael H.
            • January 29, 2008
            • 7477
            Thank You
            Yes, the 4th edition was half correct. It showed a 4310 and 4311. The 4311 was correct. The 4310 was not.
            The 4310 and 4702 in the 5th edition are both incorrect.
            The 4311 is the only correct tab number for 64.
            I can't find any documentation at all on a 4702 tab number. Not sure where that number came from.
            • David P.
              • February 26, 2008
              • 17
              Dan
              Can you tell me how to decode the Julian date for 64?
              • Dan H.
                • July 31, 1977
                • 1365
                David, I believe the Julian date was a straight running number of the day for one year, 0 to 365. You must figure out which year it refers to on the part, thus 296 = Sept/Oct of 63 for mfr of the booster. Hope this is correct, somewhere I have a manual that pins it down better.
                Dan
