Can anyone tell me what the vacuum should be for a L-71 automatic at idle? In neutral my car's manifold vacuum fluctuates between 9 and 10 inch Hg. In drive the vacuum fluctuates between 6 and 7 inch Hg. I am thinking this is to low because it is so close to the power value opening of 6.5 inch Hg.
The carbs idle okay. Although, I can backout the idle mixture screws almost all the way without much change in vacuum or rpm. However, the engine will die if I turn the idle screws in all the way to about a 1/2 turn from bottom.
I am thinking this low vacuum is related to the bad hesitation/sag when I punch the throttle from a dead stop. The vacuum drops to zero and the car stumbles for a few seconds, spits a bit, and then takes off. Generally leaves a small puff of black smoke after it takes off. The car runs great otherwise. Vacuum runs steady between 12 and 14 inch Hg on the road at speeds of around 30 to 50 mph. While curising at these speeds the vacuum will jump to 15 to 17 inch Hg if you let off the throttle and drops to zero at WOT.
One intersting observation is there is NO hesitation from a dead start if the car is warmed up only long enough to close the choke plate but not warm enough to reach full operating temperature. Also, there is no hesitation if you punch the throttle from a moving start.
I know these tripower carbs are hard to tune so before I installed the tripower I tuned the car using a single 4-bbl Holley 750 cfm. I followed Ken Anderson's power tuning procedure he outlined in Vol 22, No. 2, Fall 1995 Restorer. After tuning based on Ken's article my car ran better than it had ever ran before.
I then installed the tripower after I rebuilt all 3 carbs using original Holley rebuild kits and stock sizes for jets, power valve, accelerator nozzle, etc. Here are the list numbers for the carbs:
3659 ends
4055 center
Note the 4055 is stock for the manual transmission. For the automatic option on my 427/435 the 4056 was the stock center carb. I am running the 4055 because I have not yet located a 4056. I don't know if this can cause my problem? The only difference I can tell is the 4055 is jetted richer using 63 rather than 61 jets but uses a smaller shooter, a 21 rather than a 25. Therefore, the center carb after I rebuilt it had a small shooter (21) but larger jets (63) than the 4056 used on the automatic.
I have also tested the car with the linkage disconnected to the end carburetors and still get the hesitation. This indicates to me the problem is with the center carb. I double checked the 6.5 power valve and made sure the acclerator pump was adjusted properly. No improvement.
Thinking the problem is a lean stumble I have tried the following:
increased the shooter from a stock 21 to a 28
richened up the idle circuit by 1/4 to 1/2 turn
(the jets are already at 63 from the stock 61)
used a red accelerator cam on the no. 2 position (Anderson's recommendation)
Thinking the problem is an air leak (vacuum leak) I checked for leaks by spraying carb cleaner. I also closed off the choke plate to see if the idle increased. It did not. In fact, I could almost completely close the choke plate and would not see any difference in idle speed or vacuum. I also replaced all the vacuum lines on the car just to make sure.
I can't find any vacuum leaks, I have rebuilt the carbs using genuine Holley parts, tuned according to Ken Anderson's procedures, but nothing has made any significant improvement. Several facts seem key; 1) the car accelerates perfectly from a dead stop when it is slightly cold, 2) vacuum seems to low at idle, and 3) the car acclerates perfectly from a rolling start above 15 mph after it it warmed up.
Sorry so being so long winded, but I am hoping someone can piece these clues together and give me some suggestions to solve this problem. I am at a loss for ideas.
Ken
3659 ends
4055 center
Ken
