Re: Where Do I find the Correct O.D. Trans Cooling hose?
Lyle using an accurate measure of the fuel line bursted end, only ruined the first two inches of the fuel line I used to connect the transmission fluid line to the radiator. This piece of fuel line is 8 3/4 inches long that I cut to replace my original rubber transmission hose, so I have plenty left of usable hose to use to replace the rubber fuel line I use between the fuel filter I installed between my 70's original fuel line that I cut and connected to the dual feed chrome metal fuel line on a Holley double pumper on my ZZ1 crate engine that I installed in my 70.
and I hate to continue the thread needlessly but I originally assumed the correct size of the hose was 5/16 inch I.D. because I noted it available in that size for '63 to '82 cars from Paragon Corvette Reproductions (click on the following link)...
