Authentic 58-62 Courtesy Lamp Switch Gasket Material - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
    Truthfully, the only rubber courtesy gaskets I have seen were made as "reproductions" in the post C1 era. Thin rubber by Corvettes suppliers, and thick rubber by 55-57 Chevy suppliers.
    The part number remained the same 58-62 and is the same one in my 1938-1963 P&A catalog.
    So am I wrong? Were there 2 different kinds or has the good book been fooled by a repro part?
  • Mike E.
    • February 28, 1975
    • 5134
    Re: Authentic 58-62 Courtesy Lamp Switch Gasket Material
    Should DEFINITELY be thick!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • Bruce B.
      • May 31, 1996
      • 2930
      Doc;
      I have attached a few pictures of the gasket from the courtesy light switches on my 62 SN 2299.
      They are each around 0.095" thick and are not rubber. One side had 2 gaskets on the switch and the one pictured broke when I tried to remove it. I left the other one on the switch.
      It is hard and appears layered as you can see in the picture.
      This car is a mess but it has never been restored and much of it has not been apart. Wrong engine, trans etc., but lots of fun.
      Bruce B.
      • Loren L.
        • April 30, 1976
        • 4104
        During the National at Steamboat Springs (was it really that long ago??), Mr. Johnson of Arkansas offered up a 1960 for Bowtie consideration. As I recall, it was the ONLY straight axle car offered for Bowtie, so the traffic around the car was terrific....and it was, and is, a great car.
        I loved one aspect and had to corral and comment on it - the RH door courtesy light switch had at least 7 "layers" behind it to make it work. Wouldn't wash in "Trailer Queen Company", but there it was.
        • Roy B.
          • February 1, 1975
          • 7044
          Correct for all C1's the GoooooooooD book has been fooled by many repro parts , I've lost points on many (real original Little parts) but what can you do now????
          some repro's are becomeing original parts now!!
