Re: 427 heat soak solenoid recommend
Neil----
By the way, if you want to try a "heavy duty" solenoid, use a GM #1114493, aka Delco D-992. This piece was originally used on some 1970's Pontiacs with 455 cid engines. It should fit and work perfectly on your starter. This is about as "heavy duty" as GM solenoids get.
Will it solve your problem? I doubt it. But, at least you will have gone to the "top of the mountain" as far as GM solenoids go.
Neil----
if there is room just jumper between the 2 terminals with a screwdriver
