OK, now I'm considering repairing the cam myself. How hard would it be to remove the cam, take out the rear bearing, cut a groove in the cam ( if not there) ? Could I remove the bearing and drill the holes myself and re-install, or would a new bearing be in order? I ran the engine for about 10 minutes to see if heads would oil up. Since it is just back bearing, taking the cap out would give me access correct?
PS, if driver though Nevada / Utah on I-80, avoid Lonnie Clark at "The Shop" like the plague, he is the so-called rebuilder who refuses to make good on a $2000 rebuild that he screwed up.
