I am attempting to re-install the split spring sleeve on the lower mount bracket for the alternator. The long bolt at the bottom goes throught the mount bracket and the alternator. The alternator is stablized by the split spring sleeve approximately 5/8" long and goes into the alternator sleeve and the engine side of the bracket sleeve.
I've researched three different shop manuals and none references this step or "trick" in the process There must be a "magic" tool (I can't imagine "ring compressor" type tool that small) or an "insider's" trick to it. Surely someone out there has already been through this!!!
PLEASE HELP!!
PLEASE HELP!!
