Update on Spark Plugs-what's wrong here - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    Thanks Duke/Clem
    Last week I did this post:
    https://www.forums.ncrs.org/showthre...55310&uid=1692
    So with the new plugs in I thought I'd do a few days of driving around town, and was preparing to dive into the valve seals. But I thought I'd check out the plug, and plug wire first.
    The new plug in the #3 was wet. And I thought my ohmmeter was on the fritz as I couldn't get an ohm reading on the #3 wire. Found that it worked on the #8 plug wire, 15-16,000 ohms for the 48" wire. Then I noted a physical cut in the boot on #3.
    So it looks like a new set of plug wires are in order. Got a set of those correct Lectric Limited ones, preohm tested, but a little late in the day to start putting them on.
    Surprisingly she still idles but a little rough, and I only feel the miss once in a while on accelleration. No wonder I only got 16 mpg going to the San Jose Chapter meet.
    Jerry Fuccillo
  • Bob J.
    • December 1, 1977
    • 713
    Re: Update on Spark Plugs-what's wrong here
    Jerry, be VERY gentile installing those LL wires,they're very fragile compared to Delco wires. Probably wouldm't be a bad idea to ohm the new ones once they're installed. Good luck, Bob
    PS how come you didn't sign off "having fun"?
    • Gerard F.
      • June 30, 2004
      • 3803
      Bob,
      Had a shop change the plug wires many years ago on my 67 small block with some real good ones that are now going bad.
      Here's a question: If you had ignition shielding, did they still use the plug wire clips/bracket shown in the AIM 6-B3. I think they are the clips and brackets called out in the Paragon catalog as 915K and 916. Are there any other clips used with the shielding.
      Having fun, and I really want to do this right.
      Jerry Fuccillo
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        My experience in the past with LL plug wires - good for show, but not for go. Drove my car quite a bit back and forth across the country. Got home one time, car running badly, 5 of 8 wires no good. That was enough of the expensive wires that don't work for me.
        As an additional aside, I bought a '70 with original GM OEM wires in about '95 - They still were working fine. Quite a difference, I'd say... I'll take the deduct if I have it judged. Dennis
        • David K.
          • February 1, 1976
          • 592
          Well, this may have answered my question. I now have 280 miles on my motor and I have the dated LL wires. I just noticed tonight, an occasional spark miss. I am ready to look things over and pull the plugs, but it sounds as if the new wires, just may be suspect. Figures..... What wires do you recommend? I want to go, not worried about points.
          • Clem Z.
            • January 1, 2006
            • 9427
            to save your wires buy a good "boot puller" at the auto parts so you do not pull on the wires
            • Dennis C.
              • January 1, 1984
              • 2409
              David - I returned to the womb and started buying steel core plug wires, - Carquest (or others) for a fraction of the cost of "Judging Wires". Have never had a failure since. They look pretty much like OEM, less the ink printing stuff. Works for me. I realize there are high performance plug wires out there that will not fail, but they usually don't look OEM and cost too much. I don't mind laying out the frogskins for LL stuff (or other), but the stuff needs to work... Hate to be picky, but, hey...
              • John D.
                • December 1, 1979
                • 5507
                Dennis, What is the part number on the Carquest wires please. John D.
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  JDG, Back to you tomorrow on the PN... DC
                    Dennis-----
                    Like I've said time and again, FUNCTIONALITY trumps ORIGINALITY for me. Absolutely. Positively. Period.
                    I might think differently if I was focused on "trailer queen" type cars. But, I'm not. And, I never will be.
                      Originally posted by Gerard Fuccillo (42179)
                      Bob,
                      Jerry----
                      Yes, the brackets and clips were still used with U-69 installations and associated shielding.
                      Also, I agree with the others. Personally, I would not use the "reproduction" wires for driving. I would use a Delco or other wire set with PRE-INSTALLED terminals on both ends.
                      • David K.
                        • February 1, 1976
                        • 592
                        Gosh, I am guilty and I should know. Do the Delco or other wire brands come in the correct lenghts? I hate it when I see wires snaking around like a river all over everything. Thankfully Dennis, you can get the wires in a nearly correct color. I also hate to see yellow wires as much as I do blue gasket sealer. JMHO
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          you can get wires where they need to be cut to length and the distributor end terminals installed
                          • Bob J.
                            • December 1, 1977
                            • 713
                            Bob,
                            Hi Jerry
                            Yes, all small block cars would use the clips on the pan rail (915K) and the seperator clips (916).
                            Have some fun,Bob
                            • Stephen L.
                              • May 31, 1984
                              • 3148
                              My personal rule of thumb for plug wire resistance is about 1000 ohms/ft of wire. Values above 2000 ohms/ft are very questionable........
