Last week I did this post:
https://www.forums.ncrs.org/showthre...55310&uid=1692
So with the new plugs in I thought I'd do a few days of driving around town, and was preparing to dive into the valve seals. But I thought I'd check out the plug, and plug wire first.
The new plug in the #3 was wet. And I thought my ohmmeter was on the fritz as I couldn't get an ohm reading on the #3 wire. Found that it worked on the #8 plug wire, 15-16,000 ohms for the 48" wire. Then I noted a physical cut in the boot on #3.
So it looks like a new set of plug wires are in order. Got a set of those correct Lectric Limited ones, preohm tested, but a little late in the day to start putting them on.
Surprisingly she still idles but a little rough, and I only feel the miss once in a while on accelleration. No wonder I only got 16 mpg going to the San Jose Chapter meet.
