I am doing some engine work (cyl. heads etc.) on my 65 300 HP roadster and decided clean and lubricate the distributor. After removing the tach gear and driven gear I was supposed to be able to slide out the main shaft according to the manuals. It turns out there is some scoring on the the main shaft a several inches below the tack drive gear that keeps the shaft from sliding through the upper bushing - this can be seen and felt by looking through the tach drive bore. Can I drive the shaft through the upper bushing and plan on replacing it and then polishing the main shaft ?
Or does the main shaft have to be replaced regardless ? Thanks
Ken Geddes 37269 (This is my 2nd post in ten years - hope it goes thru.)
