Due to a jammed key cylinder, I have removed the case and cylinder. Now, how do I remove the cylinder from the case to see if I can free it up?
How to remove glovebox key cylinder
Re: How to remove glovebox key cylinder
Just under the inside of the bezel you will find a slot on each side, one has a little tab inside.
Use you trusty paper clip or small screwdriver to press that first tab down and pull to work out the lockset.
You will need to do this in several incremental steps as each of the remaining tabs come up against the bezel.
Handle carefully, once out of the lockset, those tabs are loose and tend to sprout wings.
Clear as mud huh.
Just work with it. You'll be OK.
HaND- Top
