Hello Everyone,
On pg. # 79 in the fourth edition of the 1970-72 Judging Manual is states
"On 1970 vechicles without the EEC system, the hose leading to the PCV valve is attached to the vacuum port on the carburator base and has a green spring clamp"
It doesn't say how the PCV valve is attached to the hose at the valve cover end. Do I assume that it is also a green spring clamp?
Could someone tell me what's correct - Thank you.
