54 oil pan removal - NCRS Discussion Boards
54 oil pan removal
  • Brad H.
    • August 12, 2007
    • 724
    54 oil pan removal
    54 pan without the step up front, is about 3/4 from steering thingy, what must come off to get the pan out of their,can pull exhaust probably low enough but what about steering stuff or anything to do with lower pulley, will pan slide out or hold up on parts in that compartment? Thanks Brad.
  • Joe R.
    • July 31, 1994
    • 287
    Re: 54 oil pan removal
    Brad, the pan will come off with the tie rods removed from the center arm and thew exhaust crossunder pipe swiveled down. You can then lower the rear of the pan first and it will clear (JUST BARELY!) the front.
    Joe
    • Brad H.
      • August 12, 2007
      • 724
      Joe, what releases the threaded top the nuts go on to drop down thru the center arm, nuts are free but can't pull tie rod ends down, do I need to tap down with hammer or unswivel something? Thanks Brad
      • Joe R.
        • July 31, 1994
        • 287
        Brad, the tie rod ends can be removed with a fork-like tool that can be had at any parts store. Not sure what it's called.
        Joe
        • Brad H.
          • August 12, 2007
          • 724
          Thanks JOe for the info, really app. it Brad.
          • Mike M.
            • May 31, 1974
            • 8365
            Joe
            pickle fork used to seperate tie rod ends.mike
            • Joe R.
              • July 31, 1994
              • 287
              That's the name! Thanks Mike.
                Or a tie rod end puller, if you don't want to damage the rubber boot.
