Well after 34 years of driving my 59 I decided to redo the dash and take off and redo the windshield, which had never been done under my ownership. I read all of the posts and went searching for the 4 large side bolts and 8 smaller bolts. I can now attest to the fact that you can drive a car for 34 years with the windshield being held on with the 4 side bolts and the 2 smaller center bolts that also are attached to the underside frame. None of the other bolts had any nuts on them and the above mentioned 6 were basically hand tight. There was however a ton of caulk in the channel which I assume glued the whole assembly in. I also lucked out in that my tabs are in pristine condition. I basically drove the car with the hardtop on, and the soft top was put on "loosely". Here's my question, I just spent 4 hours removing the old caulk from all of the frame, channels and the molding, even the filler strip was caulked in, there was/is caulk every where. I still have some to do on the frame and then the body channel, is there a time when there is too much caulk? or not enough? What parts need to be caulked and when should it be done? How tight do the repo rubber seals fit? Are they good enough? The caulk that I removed seemed to serve two purposes, one as a sealant and another as a filler where parts didn't fit correctly. Any advice from people who have been there before me is greatly appreciated, now that I have windshield parts all over the basement floor.
What type of caulk should I now use? Thanks again....sorry for the double psot
