OK, got the '55 running! Adjusted valves while running and a few minutes later started to get small backfiring through carb. Removed valve cover and found that #2 exhaust rocker arm nut had backed off allowing rocker arm to jump off pushrod. These are supposed to be self locking right? Hopefully a new nut will cure the problem. I hope break in is OK with all the fumbles on getting this going. I slathered cam and lifters with cam lube and ran a bottle of break in fluid as well...
Mike
Mike
