As I was cleaning the carpet, I discovered that the floorboard on my 78 pacecar was rusted out in several places. Any ideas how to repair this?
floorboard rust out
Re: floorboard rust out
Isn't the floorboard made out of fiberglass?????Are you talking about a Corvette?????
- Top
Late C-3's had a metal floor pan and many of them have holes in them from water under the carpet and road salt on the bottom side. For just a few holes to fix a driver I have made a patch out of galvinized light sheet metal then used sealer and pop riveted it in before puting in new carpet.Lyle
- Top
I learned something today!!!Metal floor pans in a Corvette. Never would have dreamed that. Any specific reason to put metal floor pans in???
- Top
Yes, that's the reason that the floorboards were changed to metal. However, there was an exception. 1975 was the first year of the catalytic converter but 1976 was the first year for the steel floor. So, there was one year with a converter that didn't use the steel floor.In Appreciation of John Hinckley- Top
Dick Whittington using Reba's 'puter- Top
Yes, 1975 used a metal shield instead of the metal floorboards. There's no way the converter could have been mounted in direct proximity to bare fiberglass. However, later model Corvettes with the steel floorboards also used a converter shield, albeit a different piece than was used for 1975 (but very similar to the 75 shield).In Appreciation of John Hinckley- Top
