57 Oil Fill Tube - NCRS Discussion Boards
57 Oil Fill Tube
  • Bruce B.
    • May 31, 1996
    • 2930
    57 Oil Fill Tube
    The oil fill tube on my 57 FI intake is a little loose, it's my fault as I turned it in a lathe to make it fit better.
    I had read about people spliting or cracking intakes while installing the oil tube so I made the tube smaller.
    Any suggestions to tighten it up?
    Silicone, JB weld, etc.
    Bruce B.
  • Edward M.
    • November 1, 1985
    • 1916
    Re: 57 Oil Fill Tube
    Get another tube, they are cheap. Clean it (if needed), stick it in the freezer for a while (to shrink if slightly), then install in your manifold.
    Warming the manifold with sunlight (not any direct heat) is also a good idea.
    • Bruce B.
      • May 31, 1996
      • 2930
      Ed,
      Thanks, I'll get one and try doing what you recommend.
      Bruce B.
