67 power brake booster - NCRS Discussion Boards
  • Dan M.
    Infrequent User
    • May 31, 1988
    • 23
    Hi All, my power brake booster has numbers on it, 5867 on one tab and 30 on the opposite side. any of these a julian date? thanks
    Re: 67 power brake booster
    Dan-----
    Not as far as anyone knows.
    • Warren S.
      • April 30, 1987
      • 100
      Dan,
      The information that I have says that the 5867 on one of your tabs and 30 on the other is: The 5867 is part of the 5455867 part number that is for 67 only and was changed on 8-22-66 to part number 5458832. Check your 67 AIM, J50-A2 on revision 3. The 30 is the julian date of Jan. 30, 1966.
      My original, Dec. 7, 1966 born 67 Corvette, brake booster has the numbers of 5867 and 309 stamped on two of it's tabs. The number 5455867 is the part number and 309 is the julian date of Nov. 5, 1966, which falls right in line with the rest of my dates made up mostly in the Sept., Oct. and Nov. dates prior to it's Dec. 7, 1966 assembly date.
      Warren
