Just started my 67 300 HP after two years sitting but before I stored the car, I changed the oil, treated the gas and had the carburetor overhauled because it ran rich at idle and never ran gas through it after putting it back on the car.
The car started and ran fine, idles at 550 on the tach but I think is still rich at idle. Crazy as it sounds the air/gas screws are out 1/2 turn from seat and engine vacuum is approx 19" and steady. If you turn the idle stop screw to increase RPM, engine sputters a little when just cracking the throttle plates, if the air/gas screws are opened another 1/2 turn that goes away but engine will not idle nice as before with screws just 1/2 turn from seat. No gasoline appears to be dripping in the carburetor and throttle plates look dry the next day. After sitting overnight a small pool of gas on passenger side intake manifold in front and behind choke stove.
I removed the carburetor and found the main body and throttle plate surface not flat. The four corners where the screws attach are like ears on the main body and were pulled slightly so I filed flat to correct The two middle screws are not tapped but I have thought about tapping and installing screws. Car idles better very smooth but still 1/2 turn out on air/gas screws and seems rich. Smaller amount of gas in manifold the next day. I am thinking I need holley gaskets but would like other suggestions because I know others have had the same issues and wanted to ask before I $$$$ on stuff I may not need. Thanks and sorry for the long post.
