Straighten Steel Wheels - NCRS Discussion Boards
  • Rob S.
    • February 26, 2008
    • 10
    Does anyone know who can straighten steel wheels. I have two that have been curbed. and wobble. I have only found one place that could do it, but they want to cut the centers out and put new ones in (which is not a option). They are "DF" wheels off my (Early) 1967 Z28 Camaro and are almost impossible to find. I wish they were as easy to find as the ones for my Corvette's Thanks for any help.
  • David K.
    • February 1, 1976
    • 592
    Re: Straighten Steel Wheels
    I will be watching this as well. I have a rim that has about .090 side run out. It would appear, as if a rather simple thing would be to mount this in a hub and then jack the rim in the direction it would need to go, until it is true. What have others done?
    • Raymond W.
      • September 30, 2003
      • 248
      I had a steel wheel from my '74 straightened by Rim and Wheel Works in Waltham, MA. I believe the cost was somewhere between $100-$150. The rim had considerable runnout and had a dent from a hydraulic jack mishap. The results were satisfactory. Here's their web site; http://rimandwheelworks.com/
      • Steven S.
        • August 29, 2007
        • 571
        I used Stockton Wheel Service http://www.stocktonwheel.com/widen_straighten2.htm
        on one of my steel 15x5.5's. I was satisfied with the results, if I recall correctly it cost in the neighborhood of $75.
        Good luck,
        Steve
