C2 headlight adjustment--easiest way - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Hi all,
    I am trying to determine the best way to allign and adjust the headlights beyond simply turning the lights on in the dark and making necessary adjustments. Is there a proven method which works well and allows for proper disbursement of the light down range?
    Craig W.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 headlight adjustment--easiest way
    Craig,
    I'm thinking there is a procedure in the AIM for headlight adjustment. Consists of a measurement of the focal point of the light beam on a wall. Measured from the floor and also centerline of the car.
    Good Luck,
    tc
    • Steven H.
      • March 23, 2008
      • 45
      Craig,
      There is a diagram showing how to aim the headlamps in the '63 Corvette Shop Manual, page 12-6.
      This is the one where the front end of the car is 25 feet from the wall.
      It has all the measurements. I need to do this but I don't have any level 25 feet to a wall (or garage door) around!
      Let me know how it goes.
      Steven
      • M W.
        • July 31, 2001
        • 835
        Thanks Steven. I hope all is well with you and your family? Take care and let's do a road trip sometime soon.
        Cheers,
        Craig
        • Donald T.
          • September 30, 2002
          • 1319
          Originally posted by Steven Hauther (48801)
          Craig,
          Steven
          I had the same problem with the lack of a level surface to complete the procedure in the manual. So I just used my C5 as a reference. The height and spread of the headlights is nearly identical to a C2. I positioned the C5 on the driveway and marked the center of the low beams with a strip of tape on the garage door. I then marked a second set with the brights. I then marked the position of the headlights as well as the rear tires on the driveway. I then positioned the C2 in the same spot and aimed the lights onto the marks on the garage door. I then drove the C2 at night and the aim was perfect.
